105 plus shipping
19mm sway bar and ill throw in the bolt in backing plates and prothane larger rear sway bar brackets/bushings also
original roush bushings also
Doberman67@aol.com
Im located in los angeles if anyone wants to pick it up
thanks
Gabe
isnt that the same size as our stock sway bar?
but then again, it is ROUSH so that right there gets cool points
1
i looked up the spec's and i thought the standard bar was 18mm
anywho, i sent a pm and a email
koni kit - hpp rstb camber/plates - cf (yikes!) polyroll resistors - TCA's WR headers/ypipe -TB hiflow cat SFC's - XCal2 -dreaming of 3L-
19MM, Yet if yours is "svt" then u have the cool points already
Correction the bar is 21mm
I checked
oh that's better. that's the same size as the BAT bar.
Moderated by  Fmr12B_dup1, path914
