Posts: 15 |
went to auto zone pulled the code from my car again... it is P-1120 and the description is throttle position sensor out of range. apparently this is not the same code for a bad tps because he said that there was another code for that. i did leave my battery unhooked for about an hour after changing the tps last time. Any suggestions on what this code may mean is again greatly appreciated!!!!!!!
Posts: 21,197 |
You put the TPS on correctly right? It can be installed wrong.
Read this post.
this one.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 15 |
i am pretty sure that i installed it correctly.....the throttle body and the tps did not exactly line up so i put it on and then rotated about ninety degrees until the screwholes lined up, although i did not feel any spring tension until just about where the holes lined up. i dont think it would be possible to rotate it any further.?
Posts: 21,197 |
The connection end needs to be tilt slightly up. Place the TPS right up to where the screw holes are and tip the right/connection side up about 20 degrees. Mate to TB and turn it down so you can put the 2 screws on. I'm wondering if you did placed it on wrong with your 90 deg. statement.
-'96 SE MTX 3L
Posts: 15 |
if that is the case i did it 180 degrees wrong! i started with it in the down position and tilted up. i will try that, it sure would be nice to get rid of that annoying little light that taunts me every time i drive somewhere! if this is the case do you think my mpg will improve? mine isnt all that bad i think its around 17 in town and 20 freeway.
Posts: 21,197 |
The computer does go into limp mode with a CE light one and runs pig rich so yes.
-'96 SE MTX 3L
