#1412673 10/17/05 12:07 AM
My 98 SVT with newer clutch and trans has a problem that just developed. When I release the clutch for the firt time of the day, the clutch will act weird. While relaseing the clutch it slips for a second. I push the clutch back in, and it runs fin the rest of the day. Other than that the clutch runs fine after that one slip. It only occurs in first gear...at least that the only gear I have noticed it in. Please help.
98 SVT Contour Stock 130,000 miles w/ minor problems
#1412674 10/17/05 12:40 AM
try posting in general, or troubleshooting. might have more luck there.
Mike 98.5 Black CSVT #5291 of 6535 (Oo.<xx>.oO) o xxxxxxxxx o
#1412675 10/17/05 12:50 AM
He posted in Troubleshooting, Transaxle forumn, here, Personal ads (probably).
Did you read my reply in troubleshooting?!
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1412676 10/17/05 06:18 PM
Sounds like a possible leaking rear main seal which is dripping oil on the flywheel overnight, then after the first use it gets burned off.
The problem though is that over time it'll get worse as the oil begins to contaminate the friction material on the clutch disc.
Check under the car at the vent hole between the tranny and the motor - my suspiscions of a leaking seal will manifest itself as a tell tale drip of oil coming out of this vent.
#1412677 10/17/05 10:01 PM
hey did you see me drive past you on 9 mile friday night? kinda looked like a chick in your car i think but i didnt get a good look
#1412678 10/18/05 12:52 AM
Yeah, I saw you last minute!! Can't pass up those clear tails and orange grill.
..Oh, and that was my chic in the car.
#1412679 10/22/05 09:15 PM
tried bleeding the clutch today, and I still have the same problem. there is no appearant oil comming from the wheep hole. any other thoughts
Moderated by  WorldTour_dup1
