#1412625 10/16/05 10:48 PM
My 98 SVT with newer ford clutch and trans has a problem that just developed. When I release the clutch for the firt time of the day, the clutch will act weird. While relaseing the clutch it slips for a second. I push the clutch back in, and it runs fine the rest of the day. Other than that the clutch runs fine after that one slip. It only occurs in first gear...at least that the only gear I have noticed it in. Please help.
98 SVT Contour Stock 130,000 miles w/ minor problems
#1412626 10/17/05 03:42 AM
I would suggest that you start by testing the clutch a litle bit.
Shift into top gear at 30 mph and with the clutch pedal fully up, floor the throttle. A weak clutch will slip under this kind of load. It may not at 30 mhp, but certainly by 40 or 45 you will detect that the engine can be reved freely without touching the clutch and without adding any appreciable acceleration to the car.
If it passes this test, then in my mind there could be one of two problems. You may have a bit of oil or grease on the clutch disc that only slips a moment until things warm up. This isn't likely, but I have seen it. The other problem would be that you likely have some air in the hydraulic clutch linkage that improves almost immediately once it is exercises. If this is the cause, you should change the clutch fluid and carefully bleed the system. If you have not done so recently, you should also change the brake fluid. It is the same fluid and they both share the same resivoir. You will see a hose off the brake master cylinder that drops down to the clutch master.
You could also have a problem with the clutch master cylinder or slave cylinder that would require replacing them, but it is far more likely that you just need fresh fluid with a good bleed to make sure there is no air.
#1412627 10/17/05 12:30 PM
As I already stated in your other post. Take care of this first, it almost HAS to be this. I have experienced this before and so has MANY others.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1412628 10/22/05 09:12 PM
bleeding clutch did not help any. Still Slipping any other thoughts
#1412629 10/23/05 01:22 PM
W
W
Sounds like you need a new clutch then.
