Might want to post in teh transaxle forumn to get a better response.
You said a"new clutch". What kind of clutch? Hows the clutch pedal feel? Firm, soft, loose? If I was a betting man, you probably need to bleed the clutch again as there may be some air in the system. Do a search in the transaxle forum or in the Duratec Maintenance forum for bleeding the brakes or cltuch (as they use the same fluid adn teh clutch is hydraulically controlled just like the brakes. The bleeder is located on the backside of teh trans facing towards the rear of teh car, looks very similar to a caliper bleeder. Our clutch isn't cable adjustable like other cars (SHO, etc) and rely on hydraulic fluid pressure.
Now is a good time to do a good flush of the brake fluid now.
