#106683 10/03/01 03:52 PM
W
wonj Offline OP
W
Am i right in assuming the Fisher damper will not be as effective for the 3L? I mean, if you switch blocks your engine harmonics will change, right? What damper would you use with a 3L? Fisher? stock 2.5L unit? stock 3.0L unit?
custom made?!?!?!
thanks!!!
The friction style UDP used by Fisher isd designed to slip when crank harmonics are detected. Basically violent enough to cause slippage. So it would work on either motor.
2000 SVT #674 - Check it out!
