Posts: 8 |
I am not a frequent poster in the forums here, I usually like to read through and learn what I can. But, my fever for power from reading has really got me thinking about getting up this SC thing! I love the idea of having a Sleeper Contour! I am sorry for posting a request for old news, but can someone please
1. Give me the specs for the output of the Vortech ? 2. And also the 0-60 sec, 1/4 times if you could!
Has anyone at all had SCing related problems with their cars?
Thanks so much!
Smoo
Posts: 7,329 |
265-295 HP at the wheels & 200 + TQ 1/4's in the high 13's with stock diff and tires (so far) Use the Search for a ton of detailed posts about this subject...
Posts: 8 |
Thanks man. I have a really slow connection here to work through the search with so I thought I would ask. Thanks very much for your info DemonSVT!
Any other takers?
Posts: 2,708 |
Go back a couple weeks on this forum and look for a thread called "Pics of my broken SC"
To be honest, it seems like every Vortech owner has had some sort of major malfunction. Bob King (rtking - 295FWHP/216ft-lbs) - shredded both prop & jack shafts Me (293FWHP/214ft-lbs) - developped an oil leak in the SC and shredded both prop & jack shafts Simon Langley (fst4dr - ???FWHP/???ft-lbs) - Broken keyway shredded jack shaft Sam (PhatSVT - 266FWHP206ft-lbs) multiple boost related problems. Corey (corey - ???FWHP/???ft-lbs) - Multiple boost related problems Tim (nvmy98svt - 260.1FWHP/198.7ft-lbs) - no apparent problems. There is another guy on the boards with a SC, I will have to hunt up his numbers. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 1,090 |
Just curious...
How can we get more torque out of our cars? How come a Focus can get 200hp/240ft-lbs by slapping on a cheaper 'Aerocharger'?
I'm just wondering why it's so easy to get humongous torque increases on a crappy Focus by so difficult on our cars to get above 220ft-lbs...
Posts: 2,708 |
The easiest way is to go to the 3L, the engine is designed to rev, and make power at high rpms... wasn't ever intended to have a lot of torque. -Mark
Posts: 3,421 |
Originally posted by WorldTour: The easiest way is to go to the 3L, the engine is designed to rev, and make power at high rpms... wasn't ever intended to have a lot of torque. -Mark I would have to agree. Its also Cheaper as well. If you know someone or know how to drop it in
Posts: 422 |
To that list you can add Brad Noon (spun rod bearing... duh) and a Cougar guy, everlast66 (243hp, blown motor)
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 2,708 |
Brad Noon's bearing can't really be blamed on the vortech, I think there were some other factors playing into Silvie's early death. As for teh Cougar... can't comment because i don't know the details. -Mark
Posts: 2,631 |
Hey Sam is now up to 266hp 206tq.  Had to give you some trouble.
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
