Posts: 116 |
In light off the posts over at newcougar.org I am a little confused about upgrading to the lower intake manifold that BAT will soon be offering complete w/19lb injectors. Right now I already plan on upgrading to the dual honed svt upper IM but I don't know if the lower will be worthwhile. A list of my mods are below as I am unsure if I need larger injectors to handle the extra power. Also there are lots of rumors going around as to when ford switched over to a returnless fuel system,sometime around 5/99? Any answers are appreciated thanks!
1999 Mystique 2.5 ATX (prod 8/99) KKM w/CAI Pro Flow 75MAF SVT TB MSDS Headers/Y Pipe High flow Cat Borla Catback
Administrator
Administrator
Posts: 702 |
Unless your vehicle is returnless (post 5/99), the SVT lower will not be immediately useful for you.
If your car is not returnless, the 10lb fuel injectors will have to be swapped over to your existing fuel rail, assuming they fit.
I've talked to Eric at BAT several times over that last month, the lowers he is getting are indeed returnless type.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 116 |
Lance,if my car was built after 5/99 then supposedly I already have the larger lower intake manifold which is returnless correct? Is there reason for me to get 19lb injectors, or not without a custom chip to advance the timing
Posts: 3,562 |
If your mods dictate a jump in injector size, buying the manifold makes good money sense because it's cheaper than buying the injectors separate. If not, it's a waste of money to add fuel your car doesn't need by adding the injectors. The question about build date vs. lower manifold sizing vs. returnless fuel system is one that has yet to be confirmed, but it seems to hold true, at least on the Cougars. If you tear into it, let us know what yours is!
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 39 |
I am right there as well i am on hold until they ship. I have a pre 98 but i do want all the svt upper half. am i screwed i am gonna buy one anyway and ill see what happens. should i go with the 3.0 or run shorter rods mill the block and go for more rpm's any comments. I also already have the msd dis-4,the ford 9mm and the jet chip performance chip would the 19lb injectors still be needed i am also gonna go headers and not sure if beefed up 2.5 or 3.0 any help please send along any info. I have a 1995 GL with ATX. please help.
1995 gl V-6 shaved trunk lowered 16" rims. custom one of a kind guages and i can get them if you like. dyed interior painted dash. ford 9mm plug wires. bat inlet tube. powdered coated intake. msd dis-4 ignition kkm air filter. honed polished intake. jet chip performance chip. Ricer wing.
Posts: 7,329 |
19lb injectors will be needed for 200HP and higher.
At your current level you do not need them.
If you do go to the 3L you will need them.
Posts: 1,861 |
Don't forget that if you use 19# injectors that you will need to recalibrate the MAF (or posibly use the SVT MAF).
If you don't, your af mixture will be off and you will be constantly setting the CEL.
Bill Jenkins, one of the first to use an SVT lower intake on a non SVT, needed to reinstall the 16# injectors to avoid these problems.
If you think that the EEC system will automatically adjust to the larger injectors, you are in for a shock.
Jim Johnson 98 SVT
Posts: 116 |
From what I gather about not needing 19lb injectors even with the I/H/E set-up on a non-Svt duratec would it be possible for me to buy the lower Svt intake from Bat and use my current injectors with it? What size injectors do non-svt duratecs come with anyway 16# or 17#'s?
Posts: 1,861 |
The non SVT comes with 16# injectors.
My guess is that the lower manifold would work if you swap over the injectors and fuel rail, but we won't know for sure until some tries it. It is hard to imagine that it would not fit or at least could not be made to fit with very little modification.
Jim Johnson 98 SVT
Posts: 1,447 |
We need to get a FAQ on injectors for these cars. I hear different things everyday....it really is confusing.
