Yes a few are installed upside down. Has to be this way unless the drivetrain is pulled. Unless they used wrong sized bolts it should not touch the trans. Motor mounts/roller restrictors could be soft enough with age to be touching the bolt. Bring it back to the place that did the work and show them the issue. I'm sure you can grind the bolt down a little.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
