99 Mercury Cougar V6 (Neco has been down since Friday)
Well for the past week i have been hearing this noise coming from the drivers front tire. So i jack her up and come to find that theres about 1/4" worth of play in the tire. So my first idea was the axle nut, so i got one today and tq it down to spec and still have play. I looked at the ball joint and see that its basically completely rotted away with no greese in it. So i go about take the knock off and all the other stuff that has to come out.
Now my question is: Is it the ball joint or the wheel bearing making the play??? I will be replacing the ball joint no matter what since its gone but i dont want to put it all together to find it was the bearing!
If i grad the lug studs with one hand and pull as i am spining the lug studs i can move it back in forth. (It= the circle plate that the lug studs are attached to) Is it regular to have play there? I would think not!
THANKS A LOT!
