I recently tried to unfasten the stabilizer link (small link bar about 1 foot long) to strut bracket connection. I put a socket onto the nut and as I turned to loosen the nut, the whole bolt began turning. The back side of the bolt is round headed so I can't use a wrench to hold it from turning.
Originally posted by Mkoine: I recently tried to unfasten the stabilizer link (small link bar about 1 foot long) to strut bracket connection. I put a socket onto the nut and as I turned to loosen the nut, the whole bolt began turning. The back side of the bolt is round headed so I can't use a wrench to hold it from turning.
Any ideas on how to undo this nut?
Thanks, MKoine
There is a hidden nut on the shaft of the link bolt - it's partially covered by the boot. Just put a wrench on that to hold it while you loosen the nut with the socket.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Mine rounded off a little so I just used an impact wrench and the nut came right off. With the bolt . I eneded up getting new endlinks since they were so rusted. However, I think the impact wrench would work on a bolt in better shape.
