#1408315 10/11/05 03:53 AM
This is not a direct question about contours but I own one and know everyone here has alot of knowledge about cars so maybe someone can help
I own a 2001 Pontiac Grand AM Se with
3.4 v6 170HP
torque 195 @ 4,000RPM
Weight 3,118
Says In The AAA Review Book That it can do 0-60 in 7.7 Seconds
So I compared this 2001 Mustang
4.6 v8
260 hp
torque 302 @ 4,000 rpm
weight 3,242
0-60 in 7.2
So the question is if they weigh almost the same but the mustang has way more horse power and torque why are they so close in time on the 0-60
also what exactly is torque and what does it help speed take off or pulling things.
Like I said not exactly about contours but may help educate e and some of the newer people to automotive cars and specs ect.
1995 Mercury Mystique 2.0 Zetec 2004 Pontiac Grand Am
#1408316 10/11/05 05:14 AM
There is soooo much more involved.
First of all, 1/2 a second is significant.
Second, there can be a big varience based on who the driver is and where they were (altitude, heat, humidity, traction available, and so on). It is not always a very good comparison to just take some published information and try to get concrete answers. I know from experience that a self respecting Mustand GT can do better than 7.2.
Horsepower and torque, at least how we measure them, are closely related. A dyno only reads torque. Horsepower is calculated by mulitplying torque times RPM (with a constant factored in).
Specs that show peak power don't really tell you enough. It is the power that gets to the ground that counts. If one car has a broader power band than another, and both have about the same peak power, the one with the broader power band will have the advantage.
It's late, and I'm going to bed. Someone else can add to this (or argue against it if you wish).
#1408317 10/11/05 05:37 AM
...and after 60 im sure you will smoke the gm for good
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
#1408318 10/11/05 05:43 AM
Jim is correct a 01 Mustang with a power to weight ratio (wich is horsepower divided by weight) of .080 and perfect conditions with a good driver would do a mid 5 second 0-60 and a low 14 second 1/4 at around 100mph. Torque in simple terms is how much power a engine has to rotate the wheels. By definition torque is the force that rotates things and in this case it is the front or rear wheels depending on the car. As jim said horsepower s just a mesurment of torque.
Hope this helps
-Will
98 T-Red SVT contour 66k dropped 1.5 inch springs and struts 94 Grand prix GTP 55 thosand original miles
#1408319 10/11/05 05:58 AM
Well This is interesting so many diffrent answers when i research check this out guys what do you think
http://www.car-videos.com/performance/view.asp?ID1=51&ID2=88
Pontiac 1999 Grand Am GT 132 mph
Ford Mustang 2000 127 mph
Pontiac 0-60 8.40 s Ford Mustang 0-60 7.90 s
But what I find more interesting is this I'm sure this forum will love it
http://www.car-videos.com/performance/view.asp?ID1=51&ID2=96
Contour SVT 144mph
0-60 7.10 s
I'm sure drivers mean a lot but i'm just interested in straight performance on a strait away no skilled driving.
confused me because the Grand Am engine torque seem so low compared to alot of considered sport cars but my research is showing diffrent I will keep looking and average a bunch of sources together.
Thanks for the time guys hope you find the links interesting.
#1408320 10/11/05 04:09 PM
first of all you are comparing it to a V6 mustang not a GT...that says 2000 mustang coupe,if it were a gt it would say GT,and the times would be significantly lower...like said earlier a '00 mustang gt can easily run a mid 5 second 0-60 run...
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#1408321 10/11/05 05:22 PM
And the Mustang is an automatic, which is usally slower than the same model with a stick....
98 Silver Frost SVT 97 BMW 540I Sport, six speed "Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future" "A coveted car should never stunt your life, but should make it more rich and interesting."
