Avey Offline OP
Alright, donor car is a 99 Contour SE with fogs. Motor is excellent, tranny is ATX and is shot. Car has some rear 1/4 panel damage. Perfect situation, I could barely even pick up a set of used headlights from the junkyards around here for the price I picked this up for. Had this not been the case I wouldn't have bothered. Truth is it's the challange that makes this appealing to me, same reason I port matched my heads and swapped cams over on my 3L instead of just a straight 3L. Overall this isn't a huge project, just gotta mock everything up on the pre98 with sheet metal screws before welding the upper rad support back in.
A couple pics: I bent the last bit of metal on the inner fender supports out of the way, I could have avoided this but taking my time fiddling with the rad support once it was loose. On my car I will be avoid bending it out of the way, either way a few quick taps of the hammer and it would go back perfectly straight, just being picky. So if you take your time you can take it out smoothly and cleanly.
I am gathering an SVT kit, I already have a set of Mach Audio HID headlights from a Focus. Going to black the inside of the headlights a bit and do a projector retro fit into the them. Convert the SE grille to black mesh style.
Lastly pick up a set of these rims:
BTW my car is black now with tan interior. I like the interior in my car so no need to touch it.
Heh and I bought this car as a fun beater to last a few months.
I would much rather do this than selling my car swapping over the 3L etc to a post 98.
96 Mystique Black On Tan V6 MTX Port Matched 01 3L, 2.5L Cams, 2.5" Exhaust Optimized y-pipe, SVT clutch, Superchips, 3L split port LIM, SVT UIM, Intake, Mustang 65mm TB, MSDS Headers. Eibach Pro Kit, Torsen Diff., Ford Racing 17" Wheels.
Oooooh, own3d by the rawburt!
I'm a bit confused, you are swapping a Post 98 front end on your pre-98 mystuque and adding the mach headligts from a focus?
..If so, that ish is hot! Good luck, take TONS of pics and keep us updated.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
Beware flaming for cross posting.
Avey Offline OP
Should have just posted it here I guess, feel free to delete either one.
I'm going to be removing the HID components out of the Mach Audio headlights and putting them in to the post 98 Contour Headlights. Basic projector retrofit, I see you have done this already on your car.
Thanks I'll post pics with my progress.
