I will do my best to explain what's going on here.
My a/c and heat both work fine BUT, the temp control knob, with ONE CLICK, up or down, will either give you ALL HEAT or ALL COLD...not much in between. It juat started doing this within the past week. Any ideas on what to look for appreciated.
jteldridge@peoplepc.com
F
F
If you get full hot/cold the door motor is likely OK. I would start with the temperature control itself. With the car off turn the knob briskly back and forth a few times, try it again. If the control corroded it might clean it off. (It's like a volume control on a radio, and those get noisy.)
I haven't tried it with the power off but I did think about the crud on the switch; not sure if it will make a difference but I will try it this afternoon. Guess if that doesn't work, I will try some electronics contact spray and see what that does.
Thanks for the reply and I'll keep you posted.
Still no help; surely I'm not the only one with this problem...
Sorry, I thought this was a political post...
