#1406864 10/09/05 12:14 AM
Chelsea Offline OP
need new bulbs for my driving lights, was looking at them and could not get passenger side bulb out? and on the drivers side...do I have to remove the battery?
help!
thx
also looking for good bulbs that are brighter than stock, any suggestions?
Thx
Silver 98'
They're a little tricky. I read that some people have romoved the headlight. You shouldn't have to remove the battery ... it'll get out without. I don't know if that's much help ...
But as for bulbs I'll highly recommend the high beam in low beam that many people have done. Even the cheapest high beam bulbs will significantly improve your lighting.
95 Contour GL 2.5L ATX Minor mods
Well the first question is what year car do you have?
For pre 98 read THIS it tells you how to remove the whole headlight.
I linked to it so you can see where and how the bulb spins in and out.
You just spin out the old bulb and spin in the new one.
YOU DON'T NEED TO REMOVE THE HEADLIGHT HOUSING.
If you remove the headlight housing you will need to re-aim your headlights.
Most people like the silverstars or replacing the bulb in the low beams with a high beam bulb.
The high beam bulb has to be modified by filing the inside of the connector so it will fit on the low beam connector.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
If you have a '95-'97 model,it is pretty difficult (and dirty!) to change the bulbs. However,once you work your hands in there and are able to grab the back of the bulb,just twist it and it should turn and pull out. Then just undo the connectors. On my '95,it is a total pain to change bulbs because 2 of them don't like to lock and unlock very well.
If you have a '98-00,with my '98 Mystique,I used to remove the entire headlight assembly. 3 screws hold it in place,but it's a stupid torx bit,so make sure you've got one of those,it's not all that common,atleast in my tool collection. 2 screws ontop of the light and one at the bottom behind the light. It's tricky to find the bottom one the first time,but once you find it,it's easier the next time. Pull the headlight assembly out,and then for each bulb,3 more little torx screws hold each bulb in. Undo the screws,and twist out the bulb.
As for brighter bulbs,I use Sylvania Silverstars. I have used them in every vehicle I've had and swear by them for a halogen bulb. If you have a 98-00,just the regular 9006 for the low beam will work fine and 9005 for the high beam. If you have a 95-97,they take the same bulbs,but the lights on 95-97s suck,so I recommend to use the high beam (9005) bulbs in the low beam sockets. All you need to do is file down the little tabs inside the connector on the bulb so that it'll fit. It's easy to do and doesn't take long. Lights are much brighter,but not blinding. Basically run 4 high beam bulbs (2 in the lows,2 in the highs) and you'll be all set. Then if you really want to piss people off at night like I do,get some bright fog lights.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
i succed changing all the bulb after several cut and burn and the help of my girlfriend smaller hand
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
Chelsea Offline OP
Thanks for the info, Replaced bulbs today.
Put in Silverstars.
Was easy, took assembly right out.
going to do foglights this week ( 1 is out anyway )
What is a good bright bulb for them? and model so I can buy befor I take out?
Thanks again
Silver 98'
Moderated by  Gerald_dup1, mbb41_dup1
