#1406858 10/09/05 12:01 AM
Chelsea Offline OP
Need new bulbs ( Driving lights not high beam ), tried to change them but could not figure out how to get old ones out?
on the drivers side it looks like I might have to take out the battery?
and on the passenger side could not get the bulb unplugged from harness?
also looking for a good bright bulb...HID? are they avail?
Thanx
Oh it's a 98 contour
Silver 98'
#1406859 10/09/05 12:04 AM
Lows and highs are the same process.
Twist a quarter turn, or so, to align the tabs with the cut out slots to enable them to fit out of the headlight housing, and pull them straigh back.. No need to remove the battery, or anything, for that matter. If you really need more space, there are three small screws that hold each headlight housing to the car.. two on top (either side) and on in the center, back, down low. Remove those three, and the housing is free, then you can maneuver the housing to an angle that you can reach the bulb itself.
When re-installing, don't touch the bulbs with your hands, or get them dirty.. wipe them off if you do.
Ray
#1406860 10/09/05 12:18 AM
Chelsea Offline OP
cool thanks...
Silver 98'
#1406861 10/09/05 02:21 AM
Oh.. and to avoid the whole "leg-humping, only-helping-because-the poster-was-a-girl, Why-didn't-you-tell-HER-to-search" thing:
"Using the search feature is a great way to find answers to common problems.. after 10 years, every problem is a "common" problem.. so.. "Search" before posting."
There.. I don't wanna hear it from anyone! LOL
Ray
#1406862 10/09/05 02:56 AM
#1406863 10/09/05 09:41 PM
Chelsea Offline OP
Changed bulbs today, was easy.
Thanks again for info.
Silver 98'
