Posts: 190 |
Hello everyone,
I am going to store my car for the wintertime. Do you have any tips?
Thanks, Derek
1999 Ford Contour SE (Black)
S&B Powerstack Air Filter
Brullen Cat-Back Exhaust System (Loud Setup)
Sylvania SilverStar Headlight Bulbs
MSN Messenger: ddasilva99@hotmail.com
Posts: 4,693 |
Change oil before storing it.
Fill the tank with fuel and add fuel stabilizer. If at all possible, store it indoors, even if it isn't heated.
Tires will loose roughly 1 lb of pressure every month or two and the pressure will drop with the temperature so make sure the tire pressure is checked bdfore storage and perhaps leave them as much as 5 lbs high. If possible, place on jack stands to take load off from tires.
If parked outside, if possible, remove battery and store inside even if not in a heated area. Trickle charge battery at 2 amps overnight before reinstalling. Do the same if the battery is left in the car.
Confirm condition of coolant including that it will protect low enough for storage conditions.
Top off all fluids.
Put it away clean, with fresh wax if possible.
Cover if you can.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,176 |
Originally posted by Big Jim: If at all possible, store it indoors, even if it isn't heated.
I know of a couple of people that would park their car in the bedroom if they could get it in there......
Bob
Posts: 363 |
When mu Mustang goes away, I do pretty much the same as Big Jim suggests. The only other thing I do is to put a tarp underneath the car. Was told this was a good thing to do if you park it on concrete.
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 1,580 |
The tarp is a good idea as it stops the cement from sucking the moisture out of your tires. I however think I heard that you shouldn't put the car on jackstands while in storage because it puts significant stress on the suspension and steering. If anyone can confirm this that would be great.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 4,693 |
Originally posted by The EuroTour: The tarp is a good idea as it stops the cement from sucking the moisture out of your tires. I however think I heard that you shouldn't put the car on jackstands while in storage because it puts significant stress on the suspension and steering. If anyone can confirm this that would be great.
Good point. I should have been more specific. Best to lift so that the suspension is not extended.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 5,345 |
Also cover exhaust (duct tape) to prevent small creatures from getting in.
1996 V6 ATX 96K miles
Posts: 190 |
Posts: 4,270 |
I'm worried about flat spotting the tires, but jsut as worried about the stress put on the car if placed on jack stands, how can i lift the car off the ground without putting stress on the suspension and steering short of pacing it on tire-less rims.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 1,580 |
I guess you could set the jackstands under the suspension to relieve the stress. You just shouldn't let it hang at full droop for a long time.
** Mike **
