Posts: 8 |
Originally posted by JVT:
Didn't know it was possible for someone to even believe that.
:p
JohnYeah that is wacky stuff, what did you have besides the N20 and the SC - a sh/tload of stickers on your quarter panel ?!!! ***I guess that the acheivement is to be low 14's to high 13's with the N20 and SC then ? Later
Posts: 392 |
Originally posted by svt2000:
All my stuff is bolt on Hopefully next week, I should be able to get to mid maybe even low 14`s. But I am still waiting for a few things to arrive :p All N/A stuff that is...im sure you can do it, especially with those 2.1 sec 60' you were cutting...what i would have given for one of those!
Posts: 4,042 |
Originally posted by SVT 065 G:
im sure you can do it, especially with those 2.1 sec 60' you were cutting...what i would have given for one of those! Yeah, I've been praying for one of those for a while, can't seem to go my way. My best run netted a 2.32 60'.  That was, of course, with beg-for-grip VR4s, worn clutch and 36psi. Now, UR Stage 1 clutch, Quaife, and KDWs.  There better be an improvement, low 2.2s at least. Must....get...headers... John
Posts: 392 |
JohnJohn all that should help tremendously, EXCEPT maybe the kdw's, I found the sidewall on the kdw's is so darn stiff, I can get just about any other z-rated tire to hook better than the bfg's. Of course, yours should be an improvement since you had no tread...
Posts: 9 |
3.0 and SC
1/4-13.3 13.9 13.25
Enough said.
Posts: 4,042 |
Originally posted by JboYSVT: 3.0 and SC
1/4-13.3 13.9 13.25
Enough said. Got pics? Enough said. John
Posts: 1,225 |
Got pics?
Enough said.
John ROTFLMAO! Well put I would also like to see pictures of your 3.0 and SC...
Ryan
Latest Mod: Mirko Splitter
Posts: 1,225 |
1/4-13.3 13.9 13.25
Enough said. The more I think about it, the more weak those numbers are....assuming you were running this setup :rolleyes: IIRC Mark(Worldtour) said he could run mid to low 13's with his SC....if you add a 3.0 to that equation you should at least better that number by .3 to .4(at least) simply due to the extra torque off the line. With a quaiffe, clutch, good tires, and maybe a bulldog box I don't see why you couldn't potentially pull off 13 flat or 12's!!!!. Now that sounds fun, hmmm.... I have to stop talking about fast cars, it's making me depressed knowing that I have to wait till this summer for the 3.0, and dreams of a SC/TC are way off in the future
Ryan
Posts: 1,682 |
IIRC Mark(Worldtour) said he could run mid to low 13's with his SC....if you add a 3.0 to that equation you should at least better that number by .3 to .4(at least) simply due to the extra torque off the line. With a quaiffe, clutch, good tires, and maybe a bulldog box I don't see why you couldn't potentially pull off 13 flat or [b]12's!!!!. Now that sounds fun, hmmm.... I have to stop talking about fast cars, it's making me depressed knowing that I have to wait till this summer for the 3.0, and dreams of a SC/TC are way off in the future  [/b] yeah right. first you would HAVE to lower compression to get the s/c on the 3.0 conversion. also, mark does not have track times... mearly g-tech and some speculation. the only s/c tour i saw at the track was pulling mid 14s. with the added torque of the 3.0 you could probably get into the 13s, maybe mid to lows if you are good.
Posts: 156 |
OCT 3, 2001 9:10 PM
R/T .884 60' 2.364 330 6.204 1/8 9.389 MPH 76.57 1000 12.134 1/4 14.442 MPH 95.89
My personal best.
2000 SVT Contour Silver
IN Process "3.0L w/Turbo"
Born In Kansas on 12/16/99 Engine Died on 6/18/2002 18,223 still at Ford as of 7/5/02
#986 of 2150
