Originally posted by SVTJOE1:
Chris, The X-type Jag is a 3.0 Duratec right??? Who warmed over that one??
Joe
Jag warmed it over. Reportedly it has different heads similar to the Jag V8 heads. The Jag heads put the cams directly over the valves and the valves are directly pushed by the cams without any additional fingers or followers. The combustion chambers are also different.
I don't know which valve train system actually works better though. The Ford system provides for a lot more valve action then has even been utilized, even on the Cobra. By slight comparison, the Lincoln Mark VIII engine produced 280 HP with 4.6 litres (290 on the LSC) while the Jag produces 290 HP with only 4.0 litres, but the Jag uses variable valve timing while the Lincoln did not. In the near future when the Mark VIII engine is revived for the Mercury Maurader (and optional engine on the Lincoln Town Car) is is reported to have 300 HP.
I suspect that the two different aproaches to valve train are really nearly equalivant in power with the given stock cam profiles. Jag just needed to be different. Variable valve timing would be beneficial to either engine.
