9
9
I'm getting a clicking noise from the shift lever location. I believe it's the mechanish that requires you to press the brake pedal to be able to shift into gear. It seems to be tripping on and off as soon as the car is started and put in gear. Any advise on pinpointing the problem would be greatly appreciated.
98 Contour SE 24V V6 ATX 99 Passat GLX 30V V6 ATX Tiptronic
well its going to make that noise when you put the car in gear, its doing its job. now if its doing that while its just sitting there then you may have problems.
'96 Contour GL ATX 2.5 v6 -- Daily Driver '93 SVT Lightning -- The Toy
I had a problem with the brake-shift interlock a few years back, it got stuck locked and I had to stick a screwdriver under the center console and wiggle it around for the manual release every time I wanted to shift out of park. Eventually I just took the thing out. Only side effect is I can shift the gears any time, car on or off, brake on or off.
While trying to fix it I learned that control of the interlock goes through a little box called the Instrument Interface Module. So here's a suggestion: unplug the connector for the IIM, and listen for your click when you usually get it. If no click when the IIM is unplugged, it's a good bet your interlock is the mystery clicker.
The O/D on-off switch on the gearshift also runs through the IIM but I don't remember what else. As a caveat I have never tried this myself.
To find the IIM: get under the steering wheel (try sitting on the passenger seat, lean over onto the driver seat (put the parking brake down!), then slide your head and torso under the steering wheel. Use a flashlight. Look far up under the dashboard, toward the driver-side of the steering wheel. The IIM is a green box, about 2" on each side. Except the side facing you is not green, it's black. The rest is green. Pull the plug. IIRC, it might be easier to take the box off of its' mounting bracket before you undo the connector. Can't remember exactly how to dismount it but I know it was a pain to reach it and work with it in that position.
'95 Contour GL, Zetec/ATX Repairs: * wheel bearings * sway bar stop * CV joint * alternator * shift interlock * heater tube * VSS * tensioner * ingition coil * wire harnesses * ball joint * Why do I still love it?
