Page 2 of 2 1 2
#1399897 10/08/05 10:51 PM
Y
Y
could try to find a replacement at home depot?
since i was all noobish and did not know where the "cock" was I pulled "that small hose on the paggenger side off" then proceeded to do a "quad flush" good stuff man.
#1399898 10/09/05 06:04 PM
dharnie Offline OP
Drove all week with petcock (drain plug) 1/2 way in. It would not budge at all! Ordered a new one at Auto Zone for $4. Bought needle long nosed lock pliers. Today I jacked the car up and was ready for combat! Just to see, I put a slip joint plier on that bad boy and was able to snug it all the way! I will NEVER touch that thing again. Have a new one to hang on my garage trophy wall to remind me of all the dumb auto designers out there who give us home mechanics a fit!
Was easily able to take off small hose that goes to heater to drain & refill system with fresh coolant!
Thanks for everyone's help!
#1399899 10/10/05 01:27 AM
Thanks for bringing back repressed memories. GOD I hate that thing. Way to go Ford, making a screw head out of soft squishy plastic is just plain brilliant.
I battled it on my then-girlfriend's '96 Zetec Mystique when I flushed the coolant in an faild attempt to make the thing not run so hot.
I hope my Duratec's radiator has a better design, I'm kinda afraid to look.
Ford got it right on the '93 Cougar I had. It had a little wingnut-like thing you could turn easily by hand, and underneath was a fitting for a drain hose. Looked and worked like a little tiny faucet. I don't know why they quit using that design.. Was too easy and convenient I guess!
'99 Contour Sport V6 MTX
#1399900 10/10/05 02:04 AM
F
F
I drained my coolent on my 99 mistique about 2 years ago, don't recall a big problem with radiator plug, but this does not appear to drain all of the coolant. there appears to be a plug on the back side of the block right at the end of the starter motor near the freeze plug that looks like a block drain so one can get all of the coolant out. most any motor I have seen has a block drain plug. am going to change my coolant soon and am going to remove this plug to see if it is a water jacket drain, or oil gallery drain. any one out there know for sure which it is?
#1399901 10/10/05 02:10 AM
if you are referring to what I think you are.. it is the ECT sensor.. which you can pull to back flush the block...
Ray
#1399902 10/11/05 01:03 AM
F
F
it is a small allen plug, looks like 1/8 npt just below the ect sensor.
Page 2 of 2 1 2
