9
98gl Offline OP
9
Hi,
I am new here nad have been lurking for a couple of days. I have a 98 Contour GL with 178k that runs very well but will barely pull itself 300 ft in drive or reverse. It also makes a "whirring" noise for the first couple of minutes when started. Will a CD4E from a 99 cougar bolt to a 98 Contour GL? Can anyone tell me for sure Yes or No and why it can or can't.
I would like to put a used tranny in for now and rebuild the original myself.
Thanks
not 100% possitive but with the MTX you can not interchange between the V6 and I4 as the bell housings are different, so i don't see why that wouldn't hold for the ATX also
F
F
No, it won't work ... different size Torque converter and different bellhousing ... if you have a 4 cylinder car, you need a 4 cylinder CD4E and if you have a 6 cylinder car, you will need the 6 cylinder CD4E.
9
98gl Offline OP
9
Can the bell housing and torque converter be swapped?
The bell housing is part of the trans case. You would have to swap the entire case which would essentually be a trans rebuild.
9
98gl Offline OP
9
Thanks for all the input. I appreciate it.
