Posts: 56 |
not sure if i should post here, but.... has anyone changed the mounts on their Zetec? i have to replace, i think, the tranny mounts. just didn't know how bad it would be in my garage. all i have is a floor jack and jack stands, and some tools
lets try this again. this time, lets try not to get bent outta shape:D
Posts: 2,483 |
Its a simple job. If you have access to air tools, use them. Otherwise.....PB Blaster, lots of PB Blaster.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 1,687 |
Kinda on that topic, would bad tranny and engine mounts be causing that wretched, teeth-rattling idle I have? I replaced the IAC and cleaned the MAF, IAT and it's STILL doing it.
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
Posts: 56 |
Originally posted by MadMerc97: Kinda on that topic, would bad tranny and engine mounts be causing that wretched, teeth-rattling idle I have? I replaced the IAC and cleaned the MAF, IAT and it's STILL doing it.
that is what mine is doing. i usually just put it in neutral when stopped. i had one of my techs tell that the drivers rear tranny mount is bad.
Posts: 1,687 |
I really need to get whatever it ends up being fixed, or I will never sell this car for a decent price.
J.T.
Posts: 56 |
has anyone changed them? i really need to know if i should have one of my techs do it, or if i could handle it myself.
Posts: 21,653 |
I have no idea what you can or cannot do. Just grab a haynes manual or ford service cd (pm me if you don't have it). All I've done is the top tranny mount which was obviously very easy. I'm sure the others take some more work, but definitely doable. But if you got someone that will do it for you (I take it that you're a shop manager?), then why not have them do it?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 56 |
Originally posted by Kremithefrog: I have no idea what you can or cannot do. Just grab a haynes manual or ford service cd (pm me if you don't have it). All I've done is the top tranny mount which was obviously very easy. I'm sure the others take some more work, but definitely doable. But if you got someone that will do it for you (I take it that you're a shop manager?), then why not have them do it?
i work in a ford parts department, so i can have a tech do it for me, i would just cost me. i also would like to think of myself as mechanicaly inclined. i have never changed mounts before, so not sure what it would consist of. i do have a haynes manual. just didn't know if someone has done it, and if it was fairly easy or not.
Posts: 37 |
I've done the front and rear roll resistors and the driver side tranny mount. Fairly easy to do. You need to set the handbrake so the car won't roll, jack up the front and put it on jackstands. Put a piece of wood on your floor jack and lift the motor just enough to take the weight off the mounts, but not enough to lift the car off the jackstands. Just a matter of pulling the old mounts off and replacing them after that. Took me about 3 or 4 hours, did it in my driveway. Good Luck, Doug
Doug
'96 Contour ZETEC
T-Red/ATX
Posts: 56 |
Originally posted by Kozmo: I've done the front and rear roll resistors and the driver side tranny mount. Fairly easy to do. You need to set the handbrake so the car won't roll, jack up the front and put it on jackstands. Put a piece of wood on your floor jack and lift the motor just enough to take the weight off the mounts, but not enough to lift the car off the jackstands. Just a matter of pulling the old mounts off and replacing them after that. Took me about 3 or 4 hours, did it in my driveway. Good Luck, Doug
don't imagine you would like to come out and help me? i will buy the pizza, beer, sodas, any of that if you would
