WOW is all I have to say about this little Neon!
strapped down....
now you strap in for this one.........
results......how about
272.9 hp & 311.5 lb-ft at the wheels!
(these are NOT SAE (or is it SEA) corrected numbers)
and as you can see in the graph, my WGA vacuum line was having issues so it wasn't holding all the boost it should have. Gotta fix that and flatten out the curve, and probably have a higher peak torque closer to 3200 rpm's
ok, enough of the blabing on to the graph...
Power mods:
Mopar Stage 1
Mopar 2-1/2" cat-back exhaust
Injen short ram intake
MSD coil pack w/ 8.5mm wires
and that's it for power stuff!
boost was a 17-18psi spike falling to 14psi at redline. Fixing that vacuum line will be my weekend project. Probably just going to replace it all w/ new lines and zip tie every other vacuum line I can find.
