Posts: 44 |
I've been searching for a little while now, but nothing yet. How do you cut the riveted bolts from the ball joint. anything would be helpful, thanks.
97 SHO
98 CSVT #3456
03 FSVT
Posts: 1,399 |
You don't cit the rivets, you drill them out. A Haynes manual, IIRC, details the procedure.
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 44 |
thanks a mill, on my way.
97 SHO
98 CSVT #3456
03 FSVT
Posts: 536 |
you can cut them out if you have an air hammer. its a lot faster then trying to drill through the rivit. all you do is take the air hammer with the right tip and cut the top off. after that it should fall out. if it doesn't then take a small punch and a hammer and punch it through.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 4,292 |
why not just use a grinder?
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 508 |
I would skip that all together and find controll arms with the ball for 68-80 dollars (usally ebay) the bushings on the arms wearout and find it's better to just replace the whole thing. But thats just me.
JD
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
Posts: 21,197 |
Originally posted by jd28: But thats just me.
JD
Yes, it is just you. $20 for greasable ball joints is the only way. The best way to remove them from the arm is to get a cutting wheel and cut a plus in the rivets. Grab an air chisel to chisel the rivets out then.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 508 |
Originally posted by todras: Originally posted by jd28: But thats just me.
JD
But new controll arm bushings, boy they add to the feel of a new suspension, sucks you can't just replace the bushings.
JD
JD a.k.a Fingers
"Don't Panic"
Posts: 3,732 |
cut an x in the head of the rivet, then air chisel it off
if your air chisel is strong enough, you *MIGHT* be able to push out the rivets with it, but if not you gotta drill them out
Russell
Oval Port 3L Nearly Done
Posts: 21,197 |
Originally posted by Russell-3L: cut an x in the head of the rivet, then air chisel it off
Or the same thing I said. Is this a new joke I wasn't let in on. I guess others just like to type.
-'96 SE MTX 3L
