I've done many rr subframe repairs and mods. Which bushings you use depends on which brackets you have. The profile of the bushings are specifically molded to work with XX brackets. However, the Prothane and ES are the same (shape). If however, you are using the stock brackets only the BAT bushings will fit.
Also, the ES and/or Prothane bushing & bracket set requires major mods to the subframe as they use a 2 bolt attachment. This will require removing the subframe from the car to correctly modify. Don't even attempt it on the car-it will eventually fail. I relate this info. from first hand experience.....
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
