So, you are talking about the plug that goes in the back of the fog light for the bulb correct? And it has weathered/corroded to the point where it is damaged? Yes, they are the same, just find a junkyard tour' with fogs (pretty sure ANY year will actually work), cut the connector off with some additional wire and splice it on. on the 95-98 tour's, the wire colors will more than likly be diffrent, though. Jst keep that in mind when splicing it.
