Posts: 52 |
just a real quick question here, (and a little history) my car has an extreme loss of power and hvae been informed due to my CEL that i need to check the IMRC and look at the bushings under the TB. I would have no problem taking the TB off but i dont know if there is a gasket that i am going to have to go and buy after i do this check, so i can replace it after i find what is wrong. (hopefully) Can someone help? thanks
Why the heck should I have to press 1 for English?
98 Contour SVT
resinator removed, boomz intake, MSDS headers(just getting started)
Posts: 1,609 |
Yep if u take the TB off u SHOULD replace the gasket.
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 1,322 |
Originally posted by starjammir: Yep if u take the TB off u SHOULD replace the gasket.
They are only a few bucks, while you have it off clean the TB and the passages.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 52 |
got any suggestions on teh easiest and most effective way to do that?
98 Contour SVT
Posts: 1,609 |
Might as well do the whole UIM cleaning while ur at it...There is a how to in the forum somewhere...someone can point it out for ya...its about 50 bucks for the parts plus the seafoam, brushes,and the spray crap (its early Im to lazy now to type)
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 4,693 |
Originally posted by bobo: just a real quick question here, (and a little history) my car has an extreme loss of power and hvae been informed due to my CEL that i need to check the IMRC and look at the bushings under the TB. I would have no problem taking the TB off but i dont know if there is a gasket that i am going to have to go and buy after i do this check, so i can replace it after i find what is wrong. (hopefully) Can someone help? thanks
I've had my throttle body off twice. In both cases, I did not anticipate before that I would be taking it off, so I did not have a gasket. Both times I was able to get by without replacing the gasket.
I would say that if you know that you are going to remove the throttle body, you really should bet a gasket. It would be preferred. Then you would not need to worry about "getting by".
Jim Johnson
98 SVT
03 Escape Limited
