As I was doing a strut swap today, I realized that I've got a left side CVJ with a blown-out boot, so I've left the job half-done on that side and will look for a replacement half-shaft. Since I'm planning on selling this car soon, I'm thinking that I may just get a salvaged half-shaft, or maybe even a whole hub/half-shaft assembly so I don't have to bother with the bearings.
Regardless, I'll be needing to remove a half-shaft, and I'm not clear on the procedure. I've done a search and seen references to a clip that holds the shaft in place on the tranny side. It seems to suggest you don't remove the clip however, but you just whale on it with a slide hammer or pry bar. That just doesn't seem right - what am I missing?
Any insight appreciated,
Brad
E
E
Not much actually. Just get everything out of the way and have at it with the slide hammer. With a few good pulls it should pop out.
** Mike ** "You might beat me in a straight line, but I'll embarass you in the turns"
You can replace the boot instead of purchasing a shaft.. but that is your call.
As for the bearings: you wouldn't affect the bearing at all by removing the axle.
Ray
Thanks for the quick response Mike. So is it just a splined shaft that goes into the differential? What was I reading about some clip, and it needs to be replaced with a new one upon re-assembly???
Thanks too to Ray! It looks like this joint has been exposed for a while and it's the original part. It's a 200K car, so I figure it's not worth the risk of just "re-booting".
I read somewhere that somebody destroyed the bearing removing the shaft. Sounds like that's not a typical experience?
That was probably from hitting the hub/studs to seperate the axle from the splined bearing within the hub.
Typically, you simply seperate the hub(bearing) from the axle's outer end, and you're good.
Just don't reuse your axle nut(locking spindle nut... one time use only) and tighten the new one to 208-214FOOT/lbs
Ray
E
E
It is a splined shaft. The clip holds it in but stays on the axle when you pop it out. I've found the best way to remove the axle from the hub is to use an air chisel with a pointed bit. You have to disconnect the tie-rod end, endlink, and lower balljoint pinch bolt before doing this though. As for replacing the clip as well as the axle nut, I'm only gonna say I've had mine apart 3-4 times and have reused all the hardware with no problems. I'm gonna leave that up to you to decide though.
Appreciate the feedback. Still not sure I understand this clip - sounds like some sort of circlip, but all of those that I've ever dealt with HAD to be removed first before the axle could come out. Please correct me if I'm wrong, but it sounds like I essentially ignore it here, other than requiring some force to overcome the clip's retaining action, yes?
I've already got everything detached from the knuckle/hub assembly (except the axle), and this side had already had the replaceable ball-joint upgrade done, so I've removed that, if only to get it out of harm's way. So given that the axle nut is still in place, all I need do now is yank on the knuckle with a slide-hammer, or maybe carefully bang it out with a BFH, and the complete shaft should just come along with it, right?
Keep those cards and letters coming!
Brad
E
E
So given that the axle nut is still in place, all I need do now is yank on the knuckle with a slide-hammer...
Whoa slow down that train! You need to first remove the axle nut and like I said before using the air chisel, pound the axle through the hub so it is completely free from the knuckle. Then you hook up your slide hammer and have it. Be careful though as these axles have a tendency to jettison quite some distances
Okay, train slowed... I was thinking I would remove the whole hub assembly WITH the axle as one unit. Then if I get a "like" assembly from the junkyard, I could just do a complete like-for-like swap. Make sense? Any reason that approach wouldn't work?
I figured it might be easier to get the axle out this way, since I'd have the hub as a "steering wheel" at the head of the axle.
