Do you know if it's feasable to swap the original CSVT dash/console and replace it with a pre-98 Mystique one ?
I'll need to check but I think the tan interior is the same for both, I'm not sure about the navy blue one.
I'll explain why : I'm looking to buy a Contour SVT, and I'm planning to put a 7in touch screen, plugged to a computer, in place of the radio. The pre-98 Mystique dash is perfect for that operation, because the radio and the small rectangular tray under it are flush mounted and the dimensions are perfect for the screen.
This is not the case with pre-98 Contour, where the tray is offset from the radio (at least an inch deeper). And the CSVT dosen't even featur the tray.
And the fact that the pre-98 Mystique dash is looking way better than the newer one help
So, what's your thoughts about that? Could it be done, with a lot of work I'm pretty sure?
Oh, and do you know if lighted interior door handle can be wired on a CSVT?
Thanks!
Etienne
