#1393616 09/24/05 01:08 AM
to start the car is a 1998 ford contour se "sport" v6 atx,
with 98xxx miles on it. what happens is during some
sweeping turns and slighty sharp turns ( on and off ramps
are the only places ive noticed) the E-brake light
sometimes flickers on and off, sometimes it just barely
lights up, then other times its all the way on, but only
for like .5 to 1 seconds. but it only happens on turns.
anyone else have this happen before? its kinda annoying but
no big deal if it just flickers and isnt really having the
e-brake on. ~thanks in advance~
#1393617 09/24/05 01:40 AM
Well known fact: the E-brake indicates the Ebrake is on...
What is slightly LESS well known is this: (NEVER GO UP AGAINST A CICILIAN... WHEN DETH IS ON THE LINE!! HA HA. AH HAHA. AH AHAHAHA.. *thud*)
j/k.. less known is that the light also indicates low brake fluid.. I assume your fluid is moving to one side, and triggering that light.. check your brake fluid level.
Ray
#1393618 09/24/05 01:40 AM
Originally posted by SenorDuckie:
... v6 atx,
Are you positive it is the e-brake light and not the engine oil light?
#1393619 09/24/05 04:57 AM
im pretty darn sure its the e-brake light, but ill double check in the morning when i go to work. thanks for the tips because ill check/top off the brake fluid while at work ( i work at goodyear =P )
#1393620 09/24/05 05:03 AM
similar problem
i had my calipers powdercoated, etc. Ever since my e-brake light won't shut off. I took the e-brake cable off the rear calipers and re-set them back on the calipers....light still stays on constantly. I'm pretty sure I'm fine on brake fluid.....but I'll check it. In the meantime do you guys have any other suggestions? Thanks!! slingersvt
98 T-Red CSVT
#1393621 09/24/05 05:08 AM
Perhaps its a switch problem on the EBRAKE handle?
Ray
#1393622 09/24/05 05:15 AM
ahah...god ray, that was funny. been awhile since I watched that movie.
98 T-Red CSVT
#1393623 09/24/05 05:23 AM
I may just pull the console and unplug it....but I want to make sure it's not slight engaged or something like that. any additional thoughts?
98 T-Red CSVT
#1393624 09/24/05 05:29 AM
My absolute fav.. bar none.
Ray
