Posts: 1,609 |
When I turn on my lights my clock does not get brighter like it used to. I tried the dimmer and nothing happened...The clock still works I just can not see it at night... Thanks
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 7,100 |
replace the bulb.. pop out the clock and the bulb is accessible from there.
Ray
'99 CSVT - Silver #222/276
Posts: 1,609 |
Okey dokie...Ill play with it tomorrow morning  ..I should just start to PM my probs to you since u are ALWAYS the first to respond lol
Posts: 7,100 |
Posts: 4,693 |
As far as I know, the only source for the bulb is the dealer. I have not been able to find it in parts stores.
If you get desperate, take the bulb with you to compare to a Honda dealer. The one for an Odyssey looks at first glance that it may be the same.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 786 |
Autopart stores sell the bulb, but it won't fit right. I have tried. The original bulb has the base soldered to the bulb. You need to get the bulb from the dealership to get a perfect fit. It comes with the base soldered to the bulb as well and is a direct fit.
Posts: 1,609 |
Okey dokie then... BILL where are you lol.
Posts: 187 |
You can just solder a small bulb across the contacts and save a bunch of money. The part from Frod is about $14.00 The bulb can be had for under $2.00
5 minutes of work = $12.00 Savings...
The Drake Equation States:
N = R* fp ne fl fi fc L
Meaning That There Is A Good Chance That We Are Not Alone.
Posts: 4,693 |
Try another dealer or two. The bulb was only about $3.00 or $4.00 the last time I had to buy one.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 24 |
the bulb was $5.00. I had mine replaced last year. Pop out the cloc, from there its simply twist and pull.
