#1392282 09/22/05 04:45 AM
I just recently put a brand new factory clutch in my csvt, and I've been noticing when I shift, the clutch seems to be sticking and sometimes hard to put into gear. When I'm driving, sometimes it wont go into gear and I have to put it back into neutral and try it again. Is this normal or is there anything I can do to stop that from happening. Thanks
#1392283 09/22/05 06:44 AM
You may have some air in the hydraulic system. Try bleeding it.
The bleeder screw is on top of the bell housing. It helps to remove the air intake tube for access. Bleeding is similar to bleeding brakes. Have an assistant pump the pedal several times and hold the pedal down while you open the bleeder. Close the bleeder immediately after the fluid spurt, and then repeat a few times. I'm not sure, but I think it takes an 8mm wrench.
#1392284 09/22/05 02:25 PM
From your OTHER clutch thread:
Originally posted by todras:
Originally posted by muntus:
Sounds like the linkage needs to be adjusted. Make the Stealership fix it. It should have been done right to begin with.
