Posts: 48 |
I just recently put a brand new clutch in my csvt, and I've been noticing when I shift clutch seems to be sticking and sometimes hard to put into gear. Is this normal or is there anything I can do to stop that from happening. Thanks
Posts: 2,033 |
could be your trans syncros...try posting in the trans forum.
Posts: 595 |
You might get more response by posting in the Transaxle forum, but not necessarilly, I guess. Since you have a csvt, we can assume that you have an MTX-75 transmission. What we can't assume is the type of clutch you put in, what other mods you did to the tranny, and who did the work, etc.
I don't know too much, but there might be a problem with how your transmission was re-installed, instead of the problem being the new clutch.
Also, what do you mean by the clutching sticking? I thought this was a good thing.
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 432 |
it could be a couple of things , did you do the trans yourself??? you might just need to bleed the clutch, or the shifter linkage might need to be adjusted
Posts: 48 |
I just got a new factory clutch put it at a Ford Dealership. What i mean by sticking is when I try to shift into gears it doesn't want to. I have to put it back into neutral a few times then try putting it in gear again.
Posts: 595 |
Sounds like the linkage needs to be adjusted. Make the Stealership fix it. It should have been done right to begin with.
Black 1998.5
3L Oval Port
Lots of other stuff
Posts: 21,197 |
Originally posted by muntus: Sounds like the linkage needs to be adjusted. Make the Stealership fix it. It should have been done right to begin with.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,693 |
And what would you adjust?
There is no clutch adjustment.
There may be some air in the hydraulic linkage though not aloowing full disengagement. Try bleeding the clutch or even better, change the clutch (and brake) fluid.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 113 |
Originally posted by king0722: I just got a new factory clutch put it at a Ford Dealership. What i mean by sticking is when I try to shift into gears it doesn't want to. I have to put it back into neutral a few times then try putting it in gear again.
I have 65,000 miles on my clutch and i have had this same problem for about a month now. I can never get into 1st or reverse on the first try.
For Sale
JL Audio 12W3-V2,
JL Audio 500 x 5 Amp,
Tsunami Cap,
Pioneer DEH-P860MP,
Brand New in Box Passanger Headlight 98+,
Rear Strut Tower Bar.
Posts: 6,760 |
You might trying going into R then 1st. I know my SHO was like that, seemed to always help...
Ryan
Trollin!
