Posts: 8 |
ive gotten half way done with the installation on my 96 tour SE MTX i wanted to know what is the easiest way to change the rear header. ive got the alternator mostly out. do i need to remove the inner and outer CV's from the pass side as well?
and do i need to remove the alternator bracket from the block? thanks so much
LUKE
96 Contour SE
V-6 MTX
the quicker the sicker
Posts: 7,100 |
Please don't cross post. It only divides the answers you get and eliminates the ability to "feed off of each others answers".
Now, If I say "yes" and someone else says "no"(in the other thread) How do you know who is right?
You don't.. if its the same thread, the right person can correct the wrong person.
Ray
'99 CSVT - Silver #222/276
Posts: 5,600 |
I saw this first so Ill answer here, dont know where the other one is. Once you have the alternator out, thats it, just push it aside. Manifold should come right out after that, then just put the header back in its place. Install header, then install alt. back where it was.
Black 1998.5 CSVT
Posts: 5,810 |
Originally posted by Ray: Please don't cross post. It only divides the answers you get and eliminates the ability to "feed off of each others answers".
Ray
I know. If I post without a question mark....then I'm right!
See My Mods
Posts: 1,746 |
Originally posted by KingpinSVT: I saw this first so Ill answer here, dont know where the other one is. Once you have the alternator out, thats it, just push it aside. Manifold should come right out after that, then just put the header back in its place. Install header, then install alt. back where it was.
