Typical cutout is 23 Psi.
Normal low side on a 70 degree day is about 32 Psi.
Low side pressure goes up with ambient temperature to 45 Psi or so on a 90 degree plus day.
If cutout is above 25 Psi and your gage is accurate go ahead and replace the switch (or adjust it, many CCP switches are adjustable), otherwise I think you are just a bit low on R134-a.
