Posts: 32 |
Followup: The first time I started the car today, the blower works fine! I did not do anything before I started the car.....
Then it's getting wired... The second time I start the car (abort 1.5 hrs after the 1st time). The blower wont blow at the beginning. Then I turn it on high wind (was on low), it started to work. It doesn't go high wind right away, the speed go up slowly, I finally gets high wind after about 1/2 minutes or so.
I still think there's a problem, but don't know what..... Any ideas?
Maroon
99 Contour SE
2.5L V6 ATX
Posts: 5,345 |
Originally posted by Darknix: Followup: The first time I started the car today, the blower works fine! I did not do anything before I started the car.....
Per one of the threads previously posted, Jeb Hoge did the switch change and then gave a big heads up that it could be the fuse.
1996 V6 ATX 96K miles
Posts: 32 |
I had read all the old posts about the blower. It seems that the fuse should be my issue.
Maroon
99 Contour SE
2.5L V6 ATX
Posts: 32 |
Ok, it failed on me this afternoon again~~~  I just went to the zonew order me a heater/blower switch and it will arrived in 2 days. Hopefully this switch can fix the problem.....
Maroon
99 Contour SE
2.5L V6 ATX
Posts: 32 |
Ok, replaced the switch but doesn't solve the problem. Blower still doesn't blow. What should be done next? Bring her to a shop?
Maroon
99 Contour SE
2.5L V6 ATX
Posts: 32 |
If I read right, I have mentioned that I checked the fuse..... I check it like a dozen times, ano breaking wire in any of the fuses, I tried to pull it out but failed so I pressed it about 10 times to make sure it is tightly in its position. But still, nothing happen.....
Maroon
99 Contour SE
2.5L V6 ATX
Posts: 5,345 |
Yes, maybe it is time to let the shop try to fix this.
