Page 2 of 2 1 2
#1390134 09/20/05 04:38 PM
Darknix Offline OP
Followup:
The first time I started the car today, the blower works fine!
I did not do anything before I started the car.....
Then it's getting wired...
The second time I start the car (abort 1.5 hrs after the 1st time).
The blower wont blow at the beginning.
Then I turn it on high wind (was on low), it started to work.
It doesn't go high wind right away, the speed go up slowly, I finally gets high wind after about 1/2 minutes or so.
I still think there's a problem, but don't know what.....
Any ideas?
Maroon 99 Contour SE 2.5L V6 ATX
#1390135 09/20/05 07:40 PM
Originally posted by Darknix:
Followup:
Any ideas?
Per one of the threads previously posted, Jeb Hoge did the switch change and then gave a big heads up that it could be the fuse.
#1390136 09/20/05 09:32 PM
Darknix Offline OP
I had read all the old posts about the blower.
It seems that the fuse should be my issue.
#1390137 09/20/05 11:08 PM
Darknix Offline OP
Ok, it failed on me this afternoon again~~~
I just went to the zonew order me a heater/blower switch and it will arrived in 2 days.
Hopefully this switch can fix the problem.....
#1390138 09/23/05 10:41 PM
Darknix Offline OP
Ok, replaced the switch but doesn't solve the problem.
Blower still doesn't blow.
What should be done next?
Bring her to a shop?
#1390139 09/24/05 12:04 AM
The fuse.
Originally posted by Tony2005:
Try this thread/post.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1003884&Forum=trouble&Words=jeb%20hoge&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=3months&Main=1002191&Search=true#Post1003884
#1390140 09/24/05 01:22 AM
Darknix Offline OP
If I read right, I have mentioned that I checked the fuse.....
I check it like a dozen times, ano breaking wire in any of the fuses, I tried to pull it out but failed so I pressed it about 10 times to make sure it is tightly in its position.
But still, nothing happen.....
#1390141 09/24/05 01:37 AM
Yes, maybe it is time to let the shop try to fix this.
Page 2 of 2 1 2
