#1390060 09/19/05 09:28 PM
9
9
I haven't seen any written recommendations on replacing the timing belt on my 2.5L Duratec. I'm currently at 90K.
98 Contour SE 24V V6 ATX 99 Passat GLX 30V V6 ATX Tiptronic
#1390061 09/19/05 09:31 PM
you havent seen any... because the Duratec has no timing belt... it has a timing chain. Its rare that it has to be replaced, but IIRC there was a recall on the timing chain, or something related to it.
#1390062 09/19/05 09:35 PM
9
9
Excellent, thanks for the good news!
#1390063 09/19/05 10:04 PM
What exactly is the problem thats goin on? Maybe if you describe your symptoms we can give you a had... that is if you are having a problem...
#1390064 09/19/05 10:06 PM
The TSB was for the tensioners, and caused clakcing upon startup, or (when more deteriorated) at all times.
Ray
#1390065 09/20/05 12:12 AM
Also the TSB was for the 95. It was corrected from the factory after that. If you have some chain rattle, the TSB in interesting information, but since the revised tensioners were installed after 95, don't expect it to solve problems for later cars.
#1390066 09/20/05 01:43 PM
9
9
No problems, I just wanted to know if it should be replaced as preventitive maintenance. Thanks again!
