#1388930 09/18/05 02:37 AM
F
F
My first post! This site is incredible...
What is the bolt size that holds the caliper braket onto the hub? Is it a T45? Is there a standard replacement bolt for this torx head bolt?
I have a '99 Mystique with rear disk brakes and can't replace the rotors without taking the caliper braket off. After 167,000 miles those bolts are hard to get off...
'99 Mystique '98 SVT
F
F
OK, after more looking around I found it... T47.
Sorry for the NOOB mistake...
Again - sweet web site!
W
W
Welcome to CEG!!
Very good job on searching!!
F
F
Welcome This is one of the best sites I have seen. Also, get some "PB b'laster" penetrating oil, it will help a lot.
Welcome.
My 99 SVT took a T50 Torx bit. I think there was some mention awhile ago that there may have been different size bolts used. Even the T50 felt a little loose, but the next size up is T55, which is too big!
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
