if you have abs you need the ones listed for the abs application
if you look behind the hub at the outside, or closer to the wheel of the outer cv joint you should see a surface that looks like a gear, but it doesn't interface with anything, that is what the abs sensor reads to determine the wheel speed
- 95 Mystique LS - Zetec/5spd
Originally posted by brapple: if you have abs you need the ones listed for the abs application
