Hello,
I have been having a problem with bucking, jerking, while at constant speed and when taking off from a stop. The constant speed bucking, jerking happens when a little gas is applied. It goes away if the pedal is pushed further (almost floored). I checked the fuel pressure at idle and I get 42.5 (high) the manual says it should be (27.5 - 33.5)
My question is, is this more likely the pressure regulator or a clogged return line? The book says to check for a clogged return line and proceed to check the pressure regulator. I am wondering because I don't want to have to take off the upper intake manifold to get at the pressure regulator. Do these go bad frequently? Would fuel system cleaner fix the clogged return line if there was one? Has anyone else had this before?
Any help is appreicated, sorry for the long post.
