Posts: 41 |
has anyone tried to paint there wheels? if sohow did they turn out? i am thinking about doing it to my car, to continue a blacked out look that i am going for. im not quite sure of the best paint to use. i was also thinkin of looking into this do it yourself powdercoating kit that i saw. but im not to sure about that yet.
Posts: 1,047 |
on my old RX7 I had a set of ROH rims in a silver painted finish just like E1 rims. I sanded them (ie: lightly scuffed) and then applied several coats of DupliColor wheel & rim paint. Easy to do,but prone to rock chips,mostly on the rear wheels. May need touch ups every once in a while. Powdercoating is probably your best bet for durability and longevity of the colour coating.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 451 |
hey i did it with engine enamel to my stock wheel. cheap and easy
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 1,047 |
Yeah,I only used 1 can of paint to do all 4 wheels and I still had like half a can left afterwards. Then I painted other stuff.
Posts: 8,301 |
I used Duplicolor wheel paint. Sanded the stock finish to get it rough, painted a few coats of color, then a few coats of clear. Easy job, and lasts pretty well. Never chipped.
-Ken V.
psycho_bass@hotmail.com
Posts: 636 |
Only problem with powder coating is you will need something to bake it on with. If you have a spare 220v outlet you can hook up a bum oven to then your all set, most people don't. Typically people by these heat lamps to do the job. Those lamps cost over $100 each and to do a good job you will need two. I have a powder coating kit and have done small stuff, but I was able to put the parts in a toaster oven that I don't use anymore. I actually bought an full sized oven too, but when we got central air installed that used up my last 220v slot so... yea. I haven't forked out the cash for those lamps, but it may be in the works especailly if I can pay them off by doing jobs like this for people that don't have the means to do it themselves.
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 275 |
Here painted e0 cost me $20.00 to do my self includes duplicolor wheel paint, duplicolor clear coat, sand paper, 2hrs sanding and 2.5 hrs painting
http://community.webshots.com/album/326337586jHPcsg
check it out
now the svt in the rim is silver model paint and a very small brush
Posts: 1,746 |
Just throwing out my opinion...
I always like the "blacked out" look, but the rims can ruin it on some cars. I'd suggest using a rim with a chrome lip. I think it will accent the car perfectly. There is a such thing as TOO black. Find some examples if it sounds worth considering or have someone photochop em.
2000 Contour SVT
SF - #542 of 2150
Posts: 663 |
Ditto
Keith P.
Killed in action-4/27/06
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 1,047 |
I agree with the too much black,but this Duplicolor wheelpaint is a graphite grey,which is the colour I painted the botoom of my car. It is an awesome colour to go with silver,black,green or blue.Hell,even looks good with red,white and many others.
