I live near Ann Arbor but would drive a ways to find someone reputible and inexpensive to work on my CSVT. The car needs
A/C repaired. Not sure whats the issue, but its leaking somewhere
Airbag light flashing, code = bad clock sping in the steering column
metallic rattle from dr side front on "sharp" bumps
either a miss or clutch chatter mostly in 1sr gear when taking off from a stop. SOmetimes it will do it when accelerating in other gears if the RPM's get below saw 1500
Any ideas?
