Posts: 425 |
i just have one quick question about the pats key, can i change the locks on my car including the starter one with a new set with all new keys without having to do something else with the car, because of the pats, just wondering.
1998 Ford Contour Se 2.5 litre Silver frost
Posts: 4,693 |
No.
When you change the ignition key you will have new pats keys with new frequencies that will require programming the car to accept the new pats keys.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 6,910 |
as long as you still have your two keys you will be able to program the new keys yourself.
just use the new key in the ignition and move the sensor away and just hold the keys next to it as you follow the programing procedture
- 95 Mystique LS - Zetec/5spd
Posts: 4,693 |
I doubt it. You will not be able to turn the ignition on with the old key or keys that still have the chip that the car recognizes.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 425 |
oh that's [censored], i got the car with only 1 pats key, and i don't want to get srcewed over royaly over at the stealership.
Posts: 6,910 |
Originally posted by Big Jim: I doubt it. You will not be able to turn the ignition on with the old key or keys that still have the chip that the car recognizes.
yes the old keys will not turn the ignition because the cylinder should be for the new key but you can still program the new keys, just hold the key and sensor away from the new key in the ignition, worked for me and I did that right after SZ
Posts: 1,786 |
You can pop the chip out of the old key and put it in the new key.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 4,693 |
Originally posted by paul martin: oh that's [censored], i got the car with only 1 pats key, and i don't want to get srcewed over royaly over at the stealership.
You got screwed by the person that sold you the car with only one key.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 712 |
I had 1 key.. then i paid like 80 bucks for a new one.. then i lost it at an amusement park.. so do i have to pay like 80 again???
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 4,693 |
Probably.
This time it would be wise to end up with three keys so that if you loose one you will be able add a third one back in by yourself. Usually there is no additional labor charge, for the dealer to add two keys instead of only one key, just the cost of the additional key.
Jim Johnson
98 SVT
03 Escape Limited
