#1370133 08/25/05 07:00 PM
dohc24v Offline OP
Hi I am contiplating the removal of the cats on my 96 contour duratec. I am thinking about removing them and running straight pipe all the way down. I have heard it before on another contour and it sounds good,loud though of course. What I am wondering is what do I have to worry about, mechanically, if I do this. Example: check engine light, back firing. etc... Has anyone tried this?
#1370134 08/25/05 07:15 PM
Y
Y
You have 3 cats. If you gut the precats, you'll need MIL eliminators to avoid a check engine light on the downstream O2's. The main cat can be replaced with straight pipe and you won't need any MIL eliminators.
Mark
#1370135 08/25/05 07:26 PM
Negligable power gains to be had from doing this. Your money is better spent elsewhere.
#1370136 08/25/05 07:28 PM
Mark
The concern is the E-Test that some provinces might have. You should check with the Alberta E-Test standards (if Alberta has, before doing this mod).
#1370137 08/26/05 04:48 AM
dohc24v Offline OP
Alberta does not have any emissions tests on vehicles to date. I think I will only remove the main cat only. Would the sound get really loud with this procedure? Thank you for your input guys.
I am looking for sound only not any particular power gains.
Thanks
#1370138 08/26/05 05:04 AM
The sound quality gets sharper & harsher when you remove a converter.
#1370139 08/26/05 08:03 AM
If youre going to remove it and it has the three bolt flange shoot me a PM, I might take it off your habds if the price is right....
www.ChicagoCEG.com 2006 White Grand Prix
#1370140 08/26/05 01:38 PM
dohc24v Offline OP
I have a magnaflow resonator that I am going to put in place of the stock one that I think will help out with the sound a little bit. Also, yes when I do remove it we will talk.
#1370141 08/27/05 01:09 AM
You have to worry about melting the bumper on the car behind you in traffic while burning the driver's eyes and the RCMP.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
