This post is also over in the Northeast Forum, But LUCA said i may have better luck with this over here... Thank's Christine!
Help folks, I know this isnt a Contour problem, but a Ford problem indeed. Can anyone around here lend me a hand with this, please???
Exhibit A: 1991 Ford Tempo, Yes go ahead and laugh...
Anyhow, last night my wife was going to the grocery store, and when she proceded to leave the store, and was halfway out into the busy highway, the lights in the car just died, but the car was still running. I had to come out and rescure her. Here is what does and doesnt work now.
The fuel pump primes and the car starts and runs fine! No alt light is on. Thank god.
WORKS: Trunk popper, air conditioner controls, (AC is broken but vents work), wipers and squirter, brake lights, turn signals, emergency flashers, brake lights.
DOESNT WORK: Headlights, horn, interior lights, trunk light, radio top dash lights, power door locks, lights on bottom of floor to light interior, dome light.
here is the crazy thing, i checked all the fuses and they were fine! I was experimenting around and i forgot i left the headlights on, and i tried to turn on the high beams, they go on!!!!! if u try to click them to stay on, nothing happens. Only if u hold the stalk in do they stay on and the little blue high beam indicator lights, if you pull back even harder on the turn signal stalk, EVERYTHING WORKS AGAIN!!!!! the radio, headlights, interior lights, power door locks, EVERYTHING!!! What the hell is going on here?? did i blow a module or one of those gigantic silver fuses??? Please help me, i'm not very good with this stuff and my wife needs the car to get back and forth. I also replaced the multifunction switch that is attached to the turn signal lever, jusr replaced the whole thing from a wrecked car, but still no dice! does the exact same thing. Maybe a wire fell out or something, or a crossed wire?
My wife thanks u in advance.....
Thanks so much!
Chris
UPDATE: I replaced the multifunction switch with one froma yard, still no dice! Only thing now is the blinkers click off when turning, and i dont have to do that manually....
