Ok I'll try to answer what I can.
I picked up the MSD box at SP Motorsports for around $325. For more information on how it works and how to install go to
www.msdignition.com. They have full instructions and write ups but you have to have Adobe Acrobat Reader to view them.
Unfortunately the fuel system is still under the control of the PCM. However I would recommend getting an aftermarket tach. My stock tach was messed up a little after I hooked up the box. Cool part is MSD can sell a tach adapter. Although when you install the wiring harness it comes with a bypass plug so you can use your stock ignition or the MSD.
As for installation....Get a professional to do it or someone who knows wiring. My friend and I spent all day wiring my box up and it was a swearing festival. But if you choose to DIY get a friend whos got some experience with engines to help. Above all else: TAKE YOUR TIME!
Now it does have a security feature. It is a small wire that goes to a switch hooked to the chasis. If the box is hooked up and the car turned off, flip the switch and power is cut to the ignition. the car cannot be started. Pretty cool in my book.
Sorry about the length of this post but if anyone else has any questions please feel free to ask.
