I've read a lot about the BAT setup on CEG. It sounds like what I'm looking for...it does come with springs and shocks, correct?
I found this site that sells some bushings and the BAT sway bar, bushings and the BAT strut/spring kit.
http://www.spmotorsports.comAs far as the BAT suspension kit goes...does it really lower an SVT and which of these two part numbers is the right kit?
95-00 2.5L V6 European Handling Kit (941-K400A)
99-02 Cougar European Handling Kit (941-K400C)
- These guys sell strut mounts & boots...is it a good idea to replace those while I'm at it?
- With the BAT kit...do you have to get a camber kit? If it's about the same leveling as the stock springs/struts, I would figure you wouldn't need it.
