Page 2 of 2 1 2
Originally posted by SVTatGT:
Todd says that 95TourSleeper has 17# injectors, but doesn't know how to use the reply button correctly so instead of telling 95TourSleeper he told MapofTazi
And why would I need to in this instance. If you can't figure out who I'm talking to you don't need to post here.
9
So the 98 SVT LIM and fuel rail are return style correct and does anyone have any pointers or helpful insight as to making this all fit because I know it takes some skill to custom fit this onto my 95, so any help from those that have done it please tell me anything usefull!!!
98 Tour SVT #1819 custom turbo..again 95 Tour SE CTA intake,DND seats, removed cat/resonator,2.5" exhaust,98 SVT UIM and TB,9" K&N,custom turbo kit,greddy turbo timer,sunpro boost,oil psi,air/fuel gauges
Why would it have to be custom unless the injectors are a strange size? You have to find the common ground in the injector harness to solder in the new injectors.
BTW the Contour has a common +VE not ground - FYI
9
I was saying custom because I thought it wasnt a direct fit and some things have to be changed in order for it to work properly and fit right, not the injectors fitting
Page 2 of 2 1 2
